Jeff Dunham in njegove govoreče lutke
Featured Video Play Icon
Jeff Dunham je eden najbolj prepoznavnih ameriških komikov. S pomočjo lutk, katerim daje glas s pomočjo govora iz trebuha, si je pridobil svetovno slavo. Med njegovimi svetovno poznanimi junaki so mrtvi terorist Achmed (t.j. Achmed the Dead Terrorist), Walter, Peanut, José na palici oz. José Jalapeño on a Stick, Bubba J in podobni.
Jeff svoje lutke oblikuje sam, ko pa so narejene, jih skenira s FARO DesignArm 3D skenerjem (https://faro.ib-caddy.com/) , jih digitalizira, da jih pripravi za nadaljno obdelavo kot je npr 3D tiskanje.
V tem videu Jeff sam razlaga kako pripravlja svoje “govoreče” prijatelje.
OPC UA / PROFINET converter
This series of products allows to integrate an OPC UA network with a PROFINET network.
In case of Siemens PLCs (or equivalent), it is possible to use S7comm protocol to get and set data into them from a OPC UA net. S7comm protocol is a Siemens protocol: this protocol is very good if it is necessary to get and set data from/to the PLC without changing the configuration of the PLC itself. This protocol will work as a debug protocol and the automation below the PLC will continue to work without any interferance.
  • The HD67B22 is an OPC UA Client / PROFINET Converter and it allows you to read/write the data from one or more OPC UA Servers using a PROFINET Master (like a SIEMENS PLC etc).
  • The HD67B45 is an OPC UA Server / PROFINET Master Converter and it allows you to read/write the data from one or more PROFINET slaves (like barcode scanners, printers, RFID, weight scales etc) using one or more OPC UA Clients.
  • The HD67B46 is an OPC UA Server / PROFINET Converter and it allows you to interface a PROFINET Master (like a SIEMENS PLC etc) with one or more OPC UA Clients in order to exchange the informations between the networks.
  • The HD67632 is a OPC UA Server / S7comm Converter and it allows you to connect a OPC UA Client with a Siemens PLC (or equivalent) in order to exchange the informations between the networks without changing the configuration and stopping the automation of the PLC.
The OPC UA communication can be encrypted, ensuring a SECURE and SAFETY communication.
Source: https://www.adfweb.com/Home/products/PROFINET_OPCua.asp?frompg=nav17_32&loc_phy=9062552&k001=e&en-k1=profinet%20vs%20opc%20ua&d=c&g=79205412655&pos=&gclid=Cj0KCQjw6-SDBhCMARIsAGbI7UiLokGbYVZ4rYeoBcpssdhIdQmcNYOgRR6ejMp8Vei3wTTyrHU0C3kaAqNFEALw_wcB
5-osno rezkanje na Grob G550
programirano s programom CAMWorks (SOLIDWORKS), preverjeno na EUREKA Virtual Machine (G-Code)
v živo prikazano na Mednarodnem industrijskem sejmu 2019 v Celju.
#ibcaddy #solidworks #camworks #EurekaVirtualMachining
Markforged X7
Največji 3D tiskalnik kompozitnih materialov podjetja Markforged je Mark X7 oz. na kratko X7.
V tem videu so predstavljene prednosti tega tiskalnika, ki lahko tiska z najlonom ali Onyx-om, kar med samim 3D tiskom lahko ojačamo z različnimi vlakni (steklena vlakna, visokotemperaturna steklena vlakna, karbon ali kevlar). Na ta način lahko dosežemo togost primerljivo ali celo večjo kot jo ima industrijski aluminij, odpornost na temperaturo pa lahko dosega 140°C.
Ohišje tega tiskalnika (kot tudi drugih Markforged tiskalnikov) je iz aluminija in ga odlikuje eleganten dizajn. Vključena tehnologija je premišljeno načrtovana in kakovostno izdelana, posledično je vzdrževanje tega tiskalnika minimalno. Vključen laserski mikrometer omogoča pomoč pri niveliranju delovne plošče, medprocesne kontrole in prilagodljivega procesa 3D tiska. 3D tiska lahko med procesom zaustavimo, če npr želimo pregledati kako poteka tisk ali pa če želimo vstaviti kak element kot npr matico ali kaj podobnega.
Za vse 3D tiskalnike Markforged je značilno, da jih upravljamo preko na dotip občutljivega zaslona. Vmesnik je enostaven in intuitiven, V kolikor potrebujemo pomoč pri tem delu, si lahko pogledamo pomoč na spletno pomoč na https://support.markforged.com/.
Spletni program Eiger je okolje, kjer pripravimo kose za tisk, obenem pa tudi nadzorujemo aktivnosti na različnih Markforged 3D tiskalnikih od kjerkoli.
